grandalf
I have a problem with the radio etc buttons on the steering wheel, the ones on the right work erratically, but none on the left. I have checked the connectors, switch pcbs etc, but cannot see anything obvious. I assume the the connections go through some sort of slip ring in the wheel, but it is not apparent how to strip down further. Has anyone had any similar problems they have found a solution to. I suppose it could be the the radio itself, the car did not have one, si I bought an original Alana from Ebay. Also in the top radio connector there is only the yellow button data lead, I thought all these cars had a cd changer lead pre-installed as well. Again any advice would be warmly welcomed.
