Get an eazi bleed kit from Halfords about £20.
Fill the bottle up with dot 4, screw on to brake resiviour , connect pressure tube to 20psi tyre ,
Now system is pressurised , go round and open each Nipple one at a time until you get clear fluid / no bubbles , get some clear tube (washer pipe ) and poke in an old drinks bottle and put that on the nipple to catch fluid
Rear left , rear right , front left , front right , clutch (optional )
That's the easy way , 2man pumping method if you've never done before isn't easy.
Keep an eye on fluid level don't run it out or your drag air in the system
YouTube eazi bleed I'm sure there will be a video
