allah86
Been having this problem every now and again....
The butterfly valve connected to the EGR valve occasionally gets stuck in the open position which causes the engine to be half-choked i.e lack of power. It requires me to open the lid and manually flick the valve closed then I get full power and can actually drive off.
This generally only happens following a time when I've had the car on for a very short time, like just moving out of the drive then back in again. The next time I come to turn on the engine is struggled because the valve is stuck.
I tried just spraying it with lube but this doesn't seem to have solved the issue.
Ideas?
yeah mate unclip the pipe that leads down to the intercooler then there are 2 bolts underneath (don't lose the gaskets) then unbolt it from the inlet manifold next to it, 3 bolts. There are 2 vac pipes on it just pull them off and label where they went. It pretty self explanatory just give it a go :)
