Jamie
Hey guy's sorry if this has been asked before did try searching.
Just got myself a mk cupra stage 2+ plus (will post the spec)
Its a big jump for my fr 2.0tfsi and must save love it.
I want to go more power but firstly want to sort a few other things like isnthere anyway to help with the spinning anything i sink the foot 1st 2dn 3rd 4th sometimes 5th its jusy spins like mad.
I dont want to waste money makinh it faster just to get more spinning.
Any suggestions would be great. Also any other suggestions of mods etc.
Thanks i advanced guys.
for grabs is my 2007 Seat Leons Cupra 2.0 TFSI . Around 117k Always bin maintained
2.0 16v TFSI BWJ
Milltek 3" Decat-Downpipe
Custom 2.5" Exhaust system with 6x4" oval tailpipe
Stage 2+ Remap with over-run pops (sounds insane)
LOBA Uprated High Pressure Fuel Pump + New cam follower
RAMAir Enlarged Intake
Gfb+ Diverter Valve
Ths intercooler
Creations PCV delte kit
Creations runner flap delte kit
RS4 Fuel Pressure Valve
Sachs Performance Organic Stage 2 Clutch
Sachs Dual-Mass Flywheel + New Slave Cylinder
Pro-Sport Adjustable Coilovers
18" BBS CH Reps 9J all round with new 225/40/18 tyres nankang ns2r semi slicks (l
quaife lsd
R8 coilpacks
De-wipered rear
Pressed number plates (have front also)
LED number plate lights
LED sidelights
LED foglights
FK Badgeless grill
Smoked side repeaters
Team HEKO Wind Deflectors
Full LED interior light conversion
I thought tyres but spoken to somone on another site said those are good tyres wouldnt makena difference
A few things:
1. Whoever said tyres won't help is an idiot. Plain and simple. Increase traction = less wheelspin - it's that simple. NS-2Rs are a semi-slick designed for the track. In cold damp conditions they will be awful, They also need some heat in them to grip properly. Keep them as a summer tyre and get a decent set of boots suitable for current weather conditions. Winters are overkill, but I would whole heartedly recommend the Michelin PS4.
2. What suspension modifications do you have? Just coilovers? Decent suspension, uprated mounts (especially the rear), anti-lift kit and proper geometry setup will help too
3. Whose map? Aggressive torque delivery with little control will always cause a loss of traction. Learning that the accelerator is not an on/off switch and to feed in the power as you gain momentum will help massively instead of just planting your foot. Anybody can intentionally invoke wheelspin by mashing the pedal, learn to feed the power in
4. If you are referring more to corner wheelspin than straight line, then an LSD will help massively too (if you actually have one - do you have any proof? Do you suffer with inside wheel spin out of corners?)
Tyres Tyres Tyres and a proper alignment to check everything.
If you are spinning up through the gears, there is one thing that clearly isn't able to maintain traction with the road surface...
All together now...... T.....
A few things:
Cheers for the replys guys.
Defo going to change the tyres i did think that must have been somone taking the piss.
All im aware is its on Coilovers not sure what else. Going to buy the snti lift kit this week see how that goes. Any suggestion on the best ones?
The map i dont have a clue im sure the guy said revo but after being on the dyno im thinking of gettinh a new map maybe java ?
Its more the wheel spin in a straight line if you control ypur foot its not to bad but i do think could be better.
The corners seem little spin but nothing worrying im in scotland and its pissinh down so roads arent the best. Inhave proof of the lsd and does seem like has it.
Really what i want to do is see if can get it spinning a bit less before going for more power.
Thanks for your patience with me not the best with these things but love leons and what her sitting spot on.
might have something to do with having a tyre thats meant for a 7.5" rim fitted to a 9" rim.along with poor tyre choice for the current conditions and treating the gas pedal as a on off switch
what camber are the coilovers running ? I'm sensing stretch tyres and negative camber. Please tell me I'm wrong
You want the correct tyres for a 9" rim (245 I think), don't waist money on more mods, pay to have it lasers aligned and setup for the road.see how it feels after that.
Have you got any receipts or evidence it's had an LSD fitted along with all your other mods?
I got the michellen ps4 tyres fitten and wow the difference it has made :D
The camber of the coilovers i dont have a clue not the best with things like that.
Going to get the wheels set up properly on monday.
Yeah have recipet for most of the mods and defo had the lsd
Im not doing anymore mods till its 100% perfect
Well booked it in today for a 3inch exausht just couldnt help myself lol
Here hoping there the correct size tyres for your 9J rim
