Mar 17, 2007
635
montrose scotland
well today i went to put the drivers side window and it would not go down so i pressed the button again and it went down about 1/2" it then went back up ok.
so i switched the car off and had the ignition 1/2 turned and tryed it again and the window worked ok.
so then tryed it agin with the car on again and my :censored: god it wouldnt work again any one had this problem.
please :help: as its doin my nut in:banghead2
cheers again andy
sounds like your window regulator is playing up. i had the same prob and have replaced mine a mine is fine now
it could be the other side. my drivers one went but would have probs with both sides
its prob just the logic the the motor playing up, electronics always play up, it should be fine really.
Try disconnecting the battery for 15mins or so. Mine play up every so often, a batt reset usually does the trick.
