strange windows
Mar 17, 2007
635
montrose scotland
well today i went to put the drivers side window and it would not go down so i pressed the button again and it went down about 1/2" it then went back up ok.
so i switched the car off and had the ignition 1/2 turned and tryed it again and the window worked ok.
so then tryed it agin with the car on again and my :censored: god it wouldnt work again any one had this problem.
please :help: as its doin my nut in:banghead2
cheers again andy
cupra tda
64
sounds like your window regulator is playing up. i had the same prob and have replaced mine a mine is fine now
cupra tda
64
it could be the other side. my drivers one went but would have probs with both sides
ian_cupra
its prob just the logic the the motor playing up, electronics always play up, it should be fine really.
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
Try disconnecting the battery for 15mins or so. Mine play up every so often, a batt reset usually does the trick.
