Stuck on brake discs and pads
Rayner1990
46
Scunthorpe
Hello
It's time for new discs and pads
Have found three set ups what are ok money to me lol
Ferodo disc and pads 78 quid
Brembo disc and pads 67 quid
Mintex disc and pads 57 quid
Brembo disc and ebc ultimax pads 70 quid
Can anybody give me some words off wisdom off which is better suited,
My driving style can be normal easy braking and other times I can rag it about abit
Seat Ibiza
1.2 sx
54 plate
Thanks in advance
Jamie
Blanco92
www.racedriversinc.com
Apr 11, 2010
2,496
Bournemouth/Cheshire
I'd go for the Brembo ones.
They're a quality, well made product that should meet the same standards as genuine SEAT ones.
If you want to really improve braking power, simply the best thing is bigger discs over the 256mm standard ones. The problem with the 1.2s is I'm told to fit either the 288mm or 312mm discs that you need different hubs. So doing the job isn't cheap.
Ferodo are very good too, but probably not worth the extra money.
Rayner1990
46
Scunthorpe
Would that be with Brembo pads or with the ebc pads??
Wouldn't mind paying £11 extra if there is abit more value paying ferodo over Brembo
Thanks for you help
I think I read to many reviews and story's that I put myself off buying things
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
Dont upgrade to 312mm on a 1.2 its a huge waste on a car that is much better on braking due to weight.
To be honest get good pads and discs avoid the likes of the cheap jap makes, if your using it for road use it wont really matter too much. Mintex would be my bet out of that list.
alcazar
There isn't a bad combination in that list.
Go for the most expensive if it makes you happy.
You tried Godfreys?
