Bananaman
Hi all,
I wonder if someone could drop their advice on this one, please?
I don't know how to best describe it, but when at low revs in first, second and sometimes even third gear, my Leon Cupra has almost stuttered as I've put my foot down. At high revs, or at higher gears, the car feels perfectly smooth, but it's got to the point in the lower gears and revs that I'm hesitant to floor it because I don't know if the power's going to be there...
I'm pulling away from junctions and roundabouts slower and steadier than my Dad!
The stutter is almost like the car is accelerating as it should but then you've briefly tapped the brake - and then it accelerates fine again. Is this what a misfire feels like? I bought a fault-reader recently which correctly picked up a faulty coolant temp sensor , but since fixing that, the car has been error-code free. But still the stutter's here.....
I don't know if it's related, but I've also noticed that the car is ticking over slightly erratically when idling. It sits at approx 800rpm, but you can see/hear/feel a very slight surging in the revs with no gear engaged.
Does anyone have any suggestions as to what could be causing this and - probably most importantly! - how much it could cost to get fixed..?!
Cheers guys!
Cheers guys!
