Tam
Santa in disguise :)
Feb 10, 2005
1,777
Near Reevo :)
Can you enable the original poster to update the thread title that they have posted.
At present you cannot which is sometimes a pain for example:
If you make a typo then its there for all to see .
If you update a thread (say readers rides with more pics) then you could add to the title "Updated <insert date> PICS!" so people can see its updated etc.etc.
Its works really well on other forums and saves multiple threads from the same people.
Go on .. you know you want too ;)
it's not in the std vb options. however there's a massive vb update due v soon.
so i'll wait to see if it's in there - then i'll look for a mod to do it
http://www.seatcupra.net/forums/showpost.php?p=1664564&postcount=1
see. this chap has obviously took his finger off the shift key far to early,and/or left his finger on the 1 key for faaaaaaaaaaar too long.It has come up before and i have been guilty of title typo's myself,if it's easy to do,it may help post the right title.If mods can do it(edit it),it may help the "help i'm about to die, i have taken the wrapper all the way off my pine tree air freshener!!!!!!"
Just as an update to this, if you make a new post, you CAN edit the title displayed .. so there must be a time limit set as to allowable changes before it is fixed.
All you need to do is find where the time limit is set :)
example post here - http://www.seatcupra.net/forums/showthread.php?t=151683
Was able to add "now changed : )" and then make a new post and then still edit the title with "and again"
I guess after a while it will lock me out of making a title change, but dont know if that will be 10mins 20mins or an hour etc.etc.
Set the time limit to 0, thinking that 0 would be infinite, but have now changed it to 99999999999999999999 minutes :)
