J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
Right im goin to be doing my first oil change on my LCR this week! What I want to know is… once the plastic under car/sump cover is removed is the access to the oil filter easy?! (sounds like a stupid question, but I thought id ask! :lol: )
And also why do I have a funny feeling the sump plug is not a hexagon and it’s a square? Is it? :confused:
If so I guess I just simply use an adjustable spanner?!
Thanks guys!
ps. look here pls! ;) http://www.seatcupra.net/forums/showthread.php?p=970140#post970140
YerMother said:
Getting the the filter is kinda awkward and a bit messy, as the lower intercooler pipe runs below it! Not really a problem if you have a FMIC though! :)
Which i do! :yes:
so any tips at all? i dont want a messy operation! :lol:
Your bound to get some spilage when removing the filter! So if your doing it on your driveway put an old rug or something underneath! I'm lucky enough to have a friend with a pit, so never worry much about making a mess! :D
F2 Stu said:
bung some engine flush while you're at it and get the engine upto temparature and then drain it.
Yes the oil will be hot:)
too late stu... oil change done today! :yes:
i did think about it but cba!
also my car is only 16 months old ( :lol: ) and done 15k with 2 oil changes, so thought it would be ok?!
how much is engine flush and is it really neccessary for my car at its age?
well like u say stu, if its a few years old with a few miles on the clock then its prob worth it! :)
maybe il do it next time?!
Dont forget you've got oil lines that get V hot from the turbo (and I've seen your Mani glowing) which can carbonise the oil and leave deposits IIRC.
The flush treatment helps dislodge the deposits.
So yes, next time do it and make sure its upto to temp before you drain.
james what oil did you put in? need to change mine at the weekend, not sure weather to go with something like magnatec/ fully synthetic ect. ect anyone know whats best to use? im on 23k
