I'm not sure how easy they are going to be to repair. The finish has tiny grooves you can see here in this close up
Cupra 280 wheel finish by scn_syphon, on Flickr
Scott
Scott
When I saw they came as standard on the Cupra i was worried about this from experience with my old leon. Sort of wish they did standard colour ones!
From the picture you can see where they cut around the edge of the wheel initially and then stopped. Looks like a clear cut off point. The refurb place may be able to do the same thing and then relacquer. Of course as I said in my other posts it means they will need to cut it back a little but it might not be that bad!I'm not sure how easy they are going to be to repair. The finish has tiny grooves you can see here in this close up
Scott
