leonlad Full Member Mar 28, 2004 1,252 91 london Oct 18, 2006 #1 anyone know where i can get something like this in the uk ? http://www.accessafuse.com/
Feel Veedubya 'velle Jun 12, 2003 4,918 2 Midlands Oct 18, 2006 #2 Blade crimp connectors (or whatever they're called) are a perfect fit in fuse holders: This sort of thing. http://www.screwfix.com/app/sfd/cat/pro.jsp?id=94652&ts=78684 That's what I used when I relocated Fuse 38, anyway.
Icecavern Active Member Jun 12, 2001 6,213 4 Berkshire, UK www.icecavern.com Oct 18, 2006 #3 They're only for use for test purposes those, I wouldn't want to use them permenantly. What are you trying to do as there may be a better way?
leonlad Full Member Mar 28, 2004 1,252 91 london Oct 18, 2006 #4 im hardwiring a road angel in it has crossed my mind to wire in a small 2.1mm dc jack into the A pillar post trim something like this , http://www.maplin.co.uk/Module.aspx?TabID=1&DOY=18m10&ModuleNo=1407&criteria= then i can just plug the RA in there trying to be as stealth as possible Last edited: Oct 18, 2006
Icecavern Active Member Jun 12, 2001 6,213 4 Berkshire, UK www.icecavern.com Oct 19, 2006 #5 Take a fused feed off the power disribution block under the drivers side dash. I would think the A3 has one just like the Leon.
