My Audi is off having the first stage of some engine work done at the moment to boost the power a bit. The standard brake setup will not be strong enough and so will up grading. I have been looking around and basically its come down to a Hi Spec 6 pot 360mm or Tarox 10 pot 330mm conversion and before anyone posts it i know both sets are quite extreme and over the top but thats me. I was just wandering if anyone had anything good or bad to say about either kit. Also from a technical point of view which brake design should stop better, six pot calipers with 360mm disc's or ten pot calipers with 330mm disc's if made by the same company using the same pads ?
