1981whips
153
if i did a TB alignment without cleaning the TB would it be ok or help in any way. wont **** anything up would it
i was told by a tuner that you needed vagcom. i asked him what the noise was doing when you had the bonnet up window down ignition on and holding your left ear or whatever it was and he said... naff all:shrug:
There was a thread posted, referencing a video that showed the difference between a Vag-Com tba and what people used to think was a tba. The video clearly shows the latter wan't a tba.
Sorry I was just stiring, there was a massive thread once with arguments a plenty and has been done to death. Not as popular as wet carpets though yet ;)
:D
I've heard you can dry your carpets by disconnecting your maf, then turning the ignition on for ten seconds. You can clearly hear a noise, proving the carpets must be drying. :thumbup:
True true. That had some good video, with intercooler pipe of showing the different between the vag alignment and battery disconnect method.
From Vag-com website:
Throttle Body Alignment
Updated 29 Jan. 2007
Ross-Tech is not responsible for any damage or problems that may result from following these instructions. They are to be used at your own risk. As always, you should refer to a Factory Repair Manual for your vehicle!
This procedure details how to perform a Throttle Body Alignment (TBA) on many VW/Audi vehicles. This procedure cycles the motorized throttle body through various states (idle, part throttle, WOT) to relearn their positions. Some examples of reasons to perform a TBA:
The vehicle's battery has been disconnected and re-connected
The ECU has been removed and reinstalled
The Throttle Body has been cleaned or removed and reinstalled
The Accelerator Pedal has been removed and reinstalled
In some vehicles, the car will not run correctly, or may not run at all without performing a TBA after one of the above operations. The TBA can be performed on both Drive-By-Wire (DBW or E-gas) as well as Cable-throttle cars as long as there is no Idle Stabilization Valve (ISV). If there is an ISV, then there is no motorized control of the throttle at all. Typically, '96-'99 VW/Audi have motorized Cable-throttle, and '00+ VW/Audi have DBW. Obviously, there are some exceptions. This should be obvious but TDI's do not have throttle bodies.
There are certain test conditions that must be met before doing a TBA:
No DTC's in the Engine Controller
Battery voltage at least 11.5 V
Throttle must be at idling position (keep your foot off the gas pedal)
Throttle body part must not be dirty (carbonized).
Coolant temperature must be between 5 and 95C
Procedure for performing a Throttle Body Alignment on Cable-Throttle Cars:
These are cars with a physical cable between the accelerator and the throttle, but WITHOUT an ISV.
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Measuring Blocks - 08]
Group 098 (Note: Some SIMOS or Marelli ECU's use Group 001 such as ADY & AEE engines)
[Go!]
[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
[Switch to Meas. Blocks] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
Procedure for performing a Throttle Body Alignment on DBW Cars using KWP-1281:
(Check to see if the engine speaks KWP-1281 by looking in the top left of the Open Controller Screen Some examples of KWP-1281 engine controllers are 2000+ Golf/GTI/Jetta/New Beetle/Audit TT 1.8T)
[Select]
[01 - Engine]
Group 060
[Go!]
Procedure for performing a Throttle Body Alignment on DBW Cars using KWP-2089:
(Check to see if the engine speaks KWP- 2089 by looking in the top left of the Open Controller Screen Some examples of KWP-2089 engine controllers are 2002+ Audi A4, 2002+ VW Passat, and Touareg)
[Select]
[01 - Engine]
[Basic Settings - 04]
Group 060
[Go!]
It should say "Basic Settings: OFF" on the top of your screen.
Click [ON/OFF/Next] to turn on Basic Settings.
It should now say "Basic Settings: ON" on the top of your screen.
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switched basic settings on. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
Click [ON/OFF/Next] to turn off Basic Settings.
It should now say "Basic Settings: OFF" on the top of your screen
Click the [Done, Go Back] button and you're all set.
