jr86
EDIT: Now here is the latest issues where i need help:
What could be wrong now, yellow engine light comes on sometimes, but no fault codes?? First when it came on, was because i unplugged one glow plug wire because it looked like it was loose, that time there was fault code concerning glow plug, but now nothing? It looks like that glow plugs are easy to change? Only that plastic pipe seems to be on my way. Car pops out some heavy diesel cloud and smell when i start car, could it mean bad glow plugs?
And still looking for those brake light wire colors? And please those colors of brake light wires are important to find as soon as possible cause the car needs to be inspected and registered. I am going to try resistors before changing lights to original.
Starting here is the old post:
Hey there, i just bought this 2004 Seat Leon 1.9 TDi with ARL engine, it looks pretty awesome, but has some problems.
16955 Brake Switch (F): Implausible Signal P0571 35 - 10 Intermittent
18062 Please check DTC Memory of instrument cluster P1654 35 - 10 Intermittent
00562 Sensor for oil level/temperature (G266) 30 - 00 Open or short to plus
Problem is, car has led taillights and also led extra brake light. That extra brake is glowing with low voltage all the time, when the power is turned on from key, but it brightens when i press brake pedal, as normal brake lights does also. So the brake lights is kinda working properly, but even replacing that switch and erasing codes with VAG-COM, i can't get that brake switch code off, i just comes back. I quess that there is problems with harness? How should i confirm that and find the solution? Glow light is also blinking in cluster. Car has cruise control but it's not working, i quess it's because of this same problem?
Then what should i do for that DTC Memory of Instrument code? I have checked that clusters plugs are in place and not loose. What else can cause that?
Car is very low at the moment, and i believe that oil level/temp sensor and it's harness is under the engine somewhere? Any help where i can find that right sensor to check the harness atleast?
photobucket.com/albums/y150/sutari/Leon/liitin_zps4b2d26d9.jpg
In this picture you can see that red circled plug, what is it? My car doesn't have that wire in it? Is it serious that it's missing, and if yes, where should that wire come from?
I hope i can find help for all these, cause i need to take it to inpection soon, and it needs to be working. Thanks anyways if someone can give atleast some information.
And sorry my english, it's not perfect but i hope you understand me
Here is a picture of the car, if someone is interested i4.photobucket.com/albums/y150/sutari/Leon/678e5818-2106-4c7c-a71b-7e752609e0b0_zps9fd31be0.jpg
