tdi sportrider sounds like a scooby?
araknipus
Hi when rolling down the road my tdi sport rider 08 57k sounds like a scooby it makes a noise just like one.
It does this even in neutral and even with the engine off a mate says it is a wheel bearing?
Someone else says its just Tyre noise. Any ideas please thanks:wtf:
araknipus
Thank you for the advice but a wheel bearing at only 57k !!!:(
araknipus
It sounds like a "bub bub bub" sound with an interval of silence between the "Bubs" lol
Bit like a Subaru sounds on the over run?
It is still the same when cornering also?
Thanks again to anybody who can shed more light on this!
araknipus
Yes it doe's Chris.. and to font off side Tyre is a ceat cheap **** Tyre the rest are Avon's.
I will swop the **** Tyre and put two new Avon's on the front at the weekend... could a wheel bearing go at only 57k though... Thanks Chris.
great_kahn
Spooge
Nov 19, 2009
2,415
Leicestershire
Given the roads then yes wheel bearing could have gone. I had one of my rear ones go at 60k. Mine was a constant drone though.
clouty86
139
sound like bearing to me to i had a front one go on my old 1.2 it only had 50k odd miles
Jan 11, 2005
680
Barnsley
A buckle in the wheel or bulge in the tyre might be a cause but my money would be a bearing. Probably near side due to the extra loading from roundabouts
araknipus
Two new front bearings and 2 new Avon's
The result is good feels and sounds like a new car
Thanks again peeps:D
Ibiza_Dave
how much were your wheel bearings if you dont mind me asking? my passenger side front is shot too, same car 58 plate 1.9tdi sportrider 58500 miles mine is really bad at 40mph then quietens down at 60 - 70
Ibiza_Dave
Do they not come as part of the hub assembly? As i was told that by a vw specialist that serviced my car?
