Internet constantly drops out even if cell signal is good or using wifi. Multiple DTC’s from the telematics. Infotainment crashes. SOS fault on dash. Unable to connect to app I gotta pull the module to check it properly. But I suspect the module is failing. Tried software updates using ODIS no change.
The fault is more frequent in heavy rain and almost guaranteed after washing the car. I suspect water ingress. Once I pull the module I should be able to check for corrosion. I can send you evidence after I get the module out but I suspect the module is toast. and will require replacement. I’ll know more next week.
