Testing injector deviation and fuel pump?
Cossie-boy
274
Hi all
I have just got VCDS, never used before, and would like to check the injectors for deviation levels and I also saw a reading for the fuel pump?
I think its measuring blocks but how do I get to them?! and should I test this on idle or whilst driving?
Many thanks in advance
VCDS virgin
Cossie-boy
274
So maybe easier than I thought!
Address 01: Engine (03L 906 018 HC)
18:46:13
181 Injection amount deviation cylinder 1 0.94 mg/stroke
182 Injection amount deviation cylinder 2 -0.05 mg/stroke
183 Injection amount deviation cylinder 3 0.46 mg/stroke
184 Injection amount deviation cylinder 4 -1.35 mg/stroke
185 Injection release status-Bit 0 00111000
This was at idle, mean anything? good, bad or ugly!
CB
Cossie-boy
274
Done another test this morning at 3500rpm in 3rd and here are the results
11:29:52
181 Injection amount deviation cylinder 1 0.55 mg/stroke
182 Injection amount deviation cylinder 2 0.45 mg/stroke
183 Injection amount deviation cylinder 3 -0.13 mg/stroke
184 Injection amount deviation cylinder 4 -0.87 mg/stroke
So guess they are all ok?
Am trying to get to bottom of a noise which happens more noticeablely above 3k rpm, but the car pulls well, good mpg, starts on button which smooth idle, I'm baffled then!
Cossie-boy
274
Ok cheers
Is there anything else I should check?
I'm sure the timing is spot on but couldn't find the torsion angle option?
Cossie-boy
274
Anyone please?
I can find the option to test the torsion synchro angle or high pressure fuel pump
Dt-spd
246
Rugby
11:29:52
Didnt know this could be checked via VCDS, I've bought one but not used it yet so will have a look. Do you get a change in noise at 3500rpm under quite heavy load ?? I get a noise change in my 2015 Leon FR 184 at that speed, sounds like the pilot injection is turning off and using just main injection.
