My CUPRA has the Reiger front splitter and it may not look aggressive as the Maxton but I like the way it finishes the front off.
That does look awesome @Maypack in terms of fitting does it sit flush or does it involve messing about with it?
Right guys I would appreciate some advice I have the facelift model 2017 cupra and wanting a front splitter but cannot make my mind up between Maxton or Reiger. Maxton does look more aggressive my Cupra is black so not sure how much of difference one would make in terms of standing out.
The Dogs!The Maxton front splitter does look more aggressive but for me it has to be the Rieger one all the way. I might of had a hand in convincing @Maypack to purchase his one after he saw mine at one of the SCN car meets.![]()
Get it painted to matchThanks guys I have got a decision to make but looks like it is siding with reiger even though maxton are literally 10 minutes away from where I live and can pick up straight away. I was just more cautious as how the reiger would look on my car especially with it being black if any of anyone would actually notice if there was a splitter attached. If my car was any other colour it would be a no brainer I would defo go for reiger.
I know there is a guy that sells the Maxton stuff on eBay, but if you buy it off him through Instagram he knocks the price down. There might be something similar for Reiger but I had the same problem as you. Plus most of their photos are just photoshopped on rather than actual pictures of their stuff. Doesn’t fill you with confidence when buying from a reseller.Is there anywhere that sells the Reiger for less than the £198 on eBay and anywhere that stocks it in Matt black?
If its genuine Reigar stuff, its fine. However Maxton customer service does not fill you with confidence. However if you want something from Maxton, hang fire as one of the site sponsors will be selling their stuff and their customer service is betterI know there is a guy that sells the Maxton stuff on eBay, but if you buy it off him through Instagram he knocks the price down. There might be something similar for Reiger but I had the same problem as you. Plus most of their photos are just photoshopped on rather than actual pictures of their stuff. Doesn’t fill you with confidence when buying from a reseller.
Based on my brothers experience with Maxton, the product quality is crap too. They say it is 3D printed but it looks more like it is dye cast or injection moulded plastic becasue of how uneven the dimensions areIf its genuine Reiagar stuff its fine. However Maxton customer service does not fill you with confidence. However if you want something from Maxton, hang fire as one of the site sponsors will be selling their stuff and their customer service is better![]()
I beleive it is supplied with self tapping screws, however, you may want to use some 3M tape as well to help stop the screws from coming loose over time.Hello, I want to put front splitter rieger and what would be the method to assemble? Do I just need to drill? Or is it necessary to paste?
Think my terrible typing is catching haha...There is only one official Reiger supplier in the UK and that sell via EBay.
To fit the Reiger Splutter you need to be able to get the front end of the car off the ground to make it e easy for yourself.
When you hold the splitter up to the car you will notice that four holes in the splitter line up with four self tapping screws already in the underside of the car. Remove these four self tappers and then offer the splitter up and the insert them. Then you will need left with 18 holes in the splitter that you need to use as a template. Using a 3mm but still into the car underside through each of the 18 holes. Then screw in the self tapping screws. Eventually you will have 22 self tapping screws in place in total. These will hold the splitter very solid.
A lot of people also use a bead of slicing around the splitter to create a seal to the underside too. All in all it’s an easy installation.
What you mean i need take off the front or just lift the car on an elevator? I didn't want to remove the front part, is there no other option?To fit the Reiger Splutter you need to be able to get the front end of the car off the ground to make it e easy for yourself.
Think you mean bead of sealant.
Thank youWhat I meant was get the car up on stands or use a car lift. You need space between the car body and the ground.
There are no car body parts that needs to be removed from the car.
A very quick photoshop of how I'll be getting the bumper and TRC splitter done in black/white.
Current:
Future:
