Has anyone got any pictures of where all the fan components are?
Just realised my fans have never come on since I bought the car, and its been thrashed a couple of times....
The fans do come on with the air-con.........how do I trick it into thinking the coolant is hot to activate cooling fans?
My firrst guess would be that your thermoswitch has failed, like DJ-LIAMC, and is not turning the fans on.
Thanx adam......it's a cupra R 03, made the mistake of removing CTS HOUSING. Do i need to know anything more that could be important or is it pretty much straight forward???
P.S. Did NOT get any rubbers with the new thermostat...................what do i need to do?
Have a read of this mate......I would personally fit new seal.
http://forums.audiworld.com/showthread.php?p=16925102
obviously you need new G12+ coolant to
The rubber seal on mine was a bitch to remove after being in place for 90k. The seal in only a couple of quid so well worth replacing.
Thank you to both, Much appreciated...............really helped!!!!
