Thought it was coil pack but now wont start?!
NottsLCR
243
Nottingham
Hi,
My LCR started to sound rough and misfire when idling to the point the battery light would come on then car would cut out. I thought it was coil packs so checked each one as per threads on hear but and seemed ok but now the car wont even start. Battery is fine and charged so at a real lost of what it could be :-(
Any ideas?????
jake
I AV MOSTLY BEEN BEATING
Feb 2, 2003
2,666
rochdale
wont start or wont turn over?
i have seen a few were the oil pick up has starved the engine and its seized.
do you have access to vag com?
NottsLCR
243
Nottingham
it wont turnover, it was till this morning and just idling really bad but now cant get it to turn over or anything.
Unfortunately i dont have access or know anyone with Vag com :-(
AntneeUK
2 Wheels 2 Many
Mar 8, 2009
1,491
Nottinghamshire
I'm sure I can help out with VAG-COM, or rather ask WiseJason. He's in the Mansfield asda like me. He's really helpful, I'm sure he won't mind me punting his services :lol:
jake
Feb 2, 2003
2,666
rochdale
hopefully its something and nothing. the car i looked at was the same, lack of power rough idle, then the engine seized. what i wasn't told was the oil pressure warning light had been on.
it could be an immobaliser problem too though
NottsLCR
243
Nottingham
Thanks chap, had someone look at it and no fault codea, new plugs and coils ok, injectors ok. This leaves the oil - it is quite thick and black been advised that as it is so thick and of course cold that it can not get through the hydrolic tapets?
This sound like a potential problem? Going to change all the oil and give it a go but thought id update for now.
NottsLCR
243
Nottingham
Yep all dash lights ok turn and it trys to start/fire but its not quite turning over and actually starting up if that makes sense
NottsLCR
243
Nottingham
The battery does turn the engine fast enough when that slowed i charged the battery up and tried again but still same.
Coils were tested with by putting a imatation test spark plug in and turning engine, this lit up so the guy said they were fine i taking his word for that really
NottsLCR
243
Nottingham
So now i have changed the oil and filter and plugs. Fuel is fine and gettin gto the injectors so now i am really stuck! Even had the rocker cover off to check the cams but all looks in order:cry:
