Hey, mates!
I bought used Ibiza 2007 1.4 100PS with BBZ engine from SEAT dealers. Theres 50k miles on the clock. I know that car had 1 owner and car was serviced properly
Everything started after driven 50 miles - EPC and Check engine lights on and limp mode.
After scanning faults and new MAP sensor, plugs, air filter and brake pedal sensor nothing is changed.
The fault codes are:
01314 - Engine Control Module: No Communications
Possible Causes
CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
Fault(s) stored in Engine Control Module
Engine Control Module recently flashed or re-mapped
6804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
Possible Causes
Leakage in Intake and/or Exhaust System
Catalyst faulty
Oxygen Sensor(s) faulty
Oxygen Sensor(s) Control faulty
17550/P1142/004418 - Load Calculation Cross Check: Lower Limit Exceeded
Possible Causes
Mass Air Flow Sensors (G70) faulty
Intake Air System faulty/leaking (false Air)
Throttle Pedal faulty
Throttle Body dirty/faulty
18265/P1857/006231 - Load Signal: Error Message from ECU
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Fault Code(s) stored in Engine Control Unit (ECU)
Unidentified codes 17961 un 17912
Any ideas, experience? What to do next?
Possible Causes
Possible Causes
Catalyst faulty
Possible Causes
Possible Symptoms
Possible Causes
