• Hi Guest There will be essential maintenance on the server on Monday 10th November from 5am meaning the website will be offline for a period of time. We will do everything to ensure the downtime is kept to a minimum.
andy88
hello only new to the site and lookin some help with my toledo
well to start it seat toledo 110 2001
only got the car and when you drive it dies of all power and sound like it chokeing it self if you know wat i mean and and some time when i rev it sounds it missin and starts spluttering can dies some time and goes in the limp mode:help::help:
i put a new egr /cleaned the inlet /all new vacum pipes /clean air flow meter/ oil /fuel fitters
plug it in there now to a vag com this wat it bringin up
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
Mileage: 190320km/118259miles
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 00046 615 1234567
No fault code found.
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 D
Component: 1M-CLIMATRONIC X0605
Coding: 00044
Shop #: WSC 00046
2 Faults Found:
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 1L AIRBAG VW5 0A 0006
Coding: 12620
Shop #: WSC 00046
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
49-10 - No Communications - Intermittent
Address 17: Instruments Labels: Redir Fail!
Part No: 1M0 920 921 B
Component: S5-KOMBIINSTR. VDO V03
Coding: 05412
Shop #: WSC 47886
Part No: IMMO
Component: IDENTNR: SEZ7Z0Y0772641
IMMO-IDENTNR: SEZ7Z0Y0772641
3 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
01314 - Engine Control Module
01316 - ABS Control Module
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00046
2 Faults Found:
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 76 Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 00046
Part No: 1J0959802F
Component: 76 Tõrsteuerger. FS0002r
Part No: 1J0959801G
Component: 76 Tõrsteuerger. BF0002r
Part No: 1J4959811C
Component: 76 Tõrsteuerger. HL0002r
Part No: 1J4959812C
Component: 76 Tõrsteuerger. HR0002r
4 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00912 - Window Regulator Switch; Front Left (E40)
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
End ---------------------------------------------------------------------
Monday,05,April,2010,14:50:23:52320
VCDS Version: Release 908.2
Data version: 20100326
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 012 AT
Component: 1,9l R4 EDC 0000SG 2815
Coding: 00002
Shop #: WSC 00046
Readiness: N/A
Coding: 0001025
Coding: 00044
Shop #: WSC 00046
Coding: 12620
Shop #: WSC 00046
Coding: 05412
Shop #: WSC 47886
Part No: IMMO
1 Fault Found:
Coding: 00006
Shop #: WSC 00046
Coding: 04097
Shop #: WSC 00046
Part No: 1J0959802F
Part No: 1J0959801G
Part No: 1J4959811C
Part No: 1J4959812C
4 Faults Found:
35-00 - -
35-00 - -
Monday,05,April,2010,14:57:58:52320
Address 01: Engine (038 906 012 AT)
14:57:56 Group 011
903 /min RPM
999.6 mbar Absolute Pres.
989.4 mbar Absolute Pres.
19.9 % Duty Cycle
