The MAF normally fails. You can try replacing it with a Mercedes MAF, which is much cheaper, and usually better than the OE bosch units.
More on that in the TDI FAQ.
matz said:Took the car out tonight and gave it a blast with the MAF sensor unplugged. The car drove fine. Plugged it back in and under hard acceleration the power dropped off like before. Double checked all this by unplugging again, another hard drive and the power was there.
Seems like its the MAF sensor after all and that the Turbo is ok?
I wonder how the power given by limp home mode is defined. Maybe I gave the impression that the power was down more than it actually was. It still drove and accelaerated but had lost all its ooomph!!
In limp home mode, does the car really crawl?
Anyone know whether the MAF breaks down into componets that fail, giving my above problems. Europarts have quoted £120 to £160 in response to me asking how much a MAF sensor was for the car. I'm wondering whether I need to spend all this to fix it.
For peace of mind, I'll probally get the car hooked up to get the fault codes read anyway in the near future!
The power given by limp mode is pre defined in the ECU set to run the car with minimum wear and tear to get u to a dealer.
Bulldozer said:PS: prc, are you portuguese?![]()
I live in Portugal though..
So, and concluding, when the turbo fails (or when i can't hear it "whispling"), it means the ECU had gone into "limp mode", right?prc said:Half of me is.I live in Portugal though..
Bulldozer said:That's what i suspected! Seems like we are compatriots![]()
A proposito, o teu mail [email protected] tem alguma coisa a haver com a BTTerra ali perto da Batalha??![]()
Bulldozer said:Well...i've been checking the car again with my brother, and we've just found the MAF was manufactured by Pierburg, which, according to TDI FAQ, are extremely reliable and is unlikely to be the source of the problem!
In addition, my brother has remembered an interesting story: some months (maybe 1 or 2 years) ago, the car had ran into the exactly same problems! Fortunately, he had to make some long trips, which were done at 90/100mph average!! Since then, problems were gone!! Why? We are wondering on the possibility of the VNT mechanism to get sticked! The car is used mostly in urban routes, and probably there is a large amount of soot build-up in the exhaust, causing the variable-vanes to malfunction...
So, is there any reliable and cheap way to clean the mechanism at the garage, or is a strong blast and/or squeeze the best way to go??
Thanks for the help given so farCheers!!
prc: Power e Speed is nearby what?? BTTerra?? The bicycle store??If so, i can tell you i'm really near you
ehehe! Hugs!!
