CupraUK
Pushing on
Aug 15, 2005
1,350
Bedfordshire
Hi all
I changed my front pads today and afterwards my fluid level is very high (I think a little bit may have gone over the top).
Should I drain some out?
Nope, I diddn't add any. I guess it was topped up last service and then when I pumped the pistons back and with the new thicker pads its taken it right up to the top.
might be worth bleeding them then in case its air, youll not really notice until you need them when they are warmed up and the pedal sinks a bit lower than you are expecting.
I was having problems with pedal travel before I changed the pads, They've not been right since I hit a curb side on. They seem MUCH better since I changed them, even whilst I'm bedding them in.
