mike_s14
105
staffs
Planning to fit a towbar tomorrow, first question how does the bumper come off? think there are torx screws behind the rear lamps and underneath anywhere else?
anybody got a pic of a towbar fitted so I can get an idea of where to cut the bumper?:)
you have got size 20torx screws have 3 down each side of bumper (in wheelarch) both rear lights need to be removed (can be a pain in the butt) the metal clips on the back are blooming tight then you have a couple of srews under lamps either side about 4 underneith i think and then pull outwards on bumper corners to release from bumper brackets.
if its a non-electrical toe bar, cant it be done without removing the bumper?
well its off, loads of screws.....
I took the rear bumper protection beam off too as the towbar replaces that
anybody tell me which wires to tap into for the towbar electrics:shrug:
ive fitted toe bars at work but all the wiring is done and i dnt know for certain where they go what will you be toeing if its a traler it will need to be wired up to the rear lights!
