Traction stuck in "off"
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
This was posted on the vagcom group recently
"If you throw a "01486 ABS test activated" the cycle did not complete correctly, and the ABS test is still in progress. Roll the car 15-20 feet then brake hard. Then, hold the steering wheel 10 degrees from center while moving in a circle for at least 4 seconds. Do each direction seperately (right circle, left circle). Do not exceed ~39mph.
If this does not work, you may have to physically realign the steering angle sensor back to within +/- 7.5 degrees of zero via the tie rods, then rerun the calibration procedure above."
Joe_Cupra-R
That's interesting, i've had the traction control light come on immediately after removing the steering wheel to fit a new wash/wiper stalk. Do you think this could be the issue and that doing the above may sort it?
MK R BOY
143
Hi
Not sure if that advice was for me or Joe.
My Steering angle sensor has been cleared and reset a number of times but returns immediately, before even driving off. We cleared it and then rerun the test and it came straight back.
Next step??
