Transmission overheating error after going in reverse on a slope
Mohamed emarah
193
38
24
Egypt
I got this error that went away after I switched the car off for 10 minutes. I had to traverse a steep slope in reverse about 6 to 7 meters long, could this have damaged something ?
Adrian300
259
113
Depends if u reversed very slowly the clutches may not have fully released, which then cause them to overheat.
Sent from my GM1913 using Tapatalk
Peller
600
191
Edinburgh
Could that cause them severe damage ?
Have you checked diagnostic screen since? It's probably a temporary issue due to the reverse manoeuvre.
If it's not showing the warning now I'd imagine it's a one off due to the uphill reverse.
Sent from my moto g(7) power using Tapatalk
Mohamed emarah
193
38
24
Egypt
Checked the diagnostic screen hasn't appeared again
Adrian300
259
113
Its just prob a warning that its overheating so u dont do any further damage to the gearbox. When i had GTR doing too many launches also came up with errors on the mfd
Reactions: Mohamed emarah
Rooster
1,188
327
Yorkshire
Some modern DSG type transmissions have a fluid level sensor, so the steep slope may have just triggered a warning as the fluid level changed due to the steep slope?
