tration control perminantly off
swinford
17
Evening all... i was driven earlier and accelerated off a roundabout but not quick enough to set the traction control off. But after changing gear the traction control light iz know staying on perminantly ... any ideas why its doing it ? Cheers
swinford
17
Will have to check that then. Would it cause an engine management light to come on eventually or isit not that serious ?
AlexK1
545
Poole
It will do eventually when it registers a fault, it could be on its way out but not registering in the engine ecu yet. Worth having a look with vagcom and see what's up
LCRIRL
57
Could also be a fault in the brake system for eg a dodgy brake light switch or a pressure sensor but as AlexK1 said best bet is too have it scanned..
LCRIRL
57
Well I just bought a vagscanner 25euro in eBay I'm handy on the spanners and for more serious stuff my Mec has vag com.. But the vagscanner has been reliable so far to be fair...
swinford
17
Could you send link to page if possible please ? I take it your from south wales isit ?
Dec 5, 2012
806
Harlow
If it's just the traction control light that's on then It will be more than likely one of the following:
MAF sensor
One of 4 abs sensors
LCRIRL
57
http://www.ebay.co.uk/itm/161023937355 I'm from the south of Ireland lad... As long as it's not a g201 or g204 fault which are brake pressure sensors located in ur brake master cylinder and are abit of pain... I had the same problem as u turned out to be a brake light switch 15euro happy days...I'm from Ireland
swinford
17
Thanks for link will have a look at that. Cheers all will see what seat say lol. Hopefully not the maf and just a abs sensorlol
