Treading the old DPF waters… sorry!
Nath.
The Gentlemans Express
Jan 1, 2006
8,617
16
EASTLEIGH, HAMPSHIRE
20.7%
I don't understand it TBH, I thought it would go down.
How on earth I had a reading of 14% before I started is beyond me considering that the car gets driven totally wrong (short trips) most of the time and what I did in her today is meant to be the best thing for it.
I dunno :shrug:
FinGerS o FuDgE
That's similar to what happend to mine. I had mine down to about 3% and since then it has only gone, even though I have kept the revs @ 2000-2200rpms in order for it to 'burn off'.
That's why I think it won't burn anything off until it hits a certain %. Then it will go into regen mode..?
It's a stupid design TBH. Really don't see why keeping at the right revs for a long journey should decrease it - But it doesn't.
Think I'll just go down the J** route now and get the DPF Deleted & remapped. I was in two minds about it, but now that AndrewJB seems to have solved the stuttering issue, it is looking even more promising..!!
/dev/null
1,651
101
It also depends what load the engine is under, not just the revs - more load means more fuel burnt and more fuel burnt means more soot! On the flip side, less load means less work for the engine - means less fuel burnt, which in turn is less temperature which means it's not hot enough to burn it off!!
McDubber1
176
East Lothian
Thanks for the info guys i think i will know for definate now when/if it goes into regen mode.
I'll keep an eye on this thread as i've found it interesting and informative and helps me learn more about my car.
Cheers again.
FinGerS o FuDgE
Pretty sure a regen kicked in on the way home just now. Had the wife and kid instead of a laptop though, so unsure what he DPF was at. I'm guessing it would have been early 20's%
Glad this topic is helping others too. We are still all unsure on how this all works correctly , so it's good to know we are getting somewhere :p
/dev/null
1,651
101
One thing I would be interested is in where are these "parameters" held? If it could be set so that first stage regen kicked in a 30% instead of 20% then that might give it a bit of a chance to get burnt off normally before starting regen mode.
Nath.
Jan 1, 2006
8,617
16
No sign's of any attempted regen sinse my last check and the loading was at 20.7% so I looked this evening and it's at 40.8% now.
I'm going to charge up the laptop, plug in Vag-Com and go for a spin, see if I can get it upto 45% and watch an active regen at work. Wish me luck.
ash101
160
Neath
Rite Guys i cant work this one out.As i said in earlyer post in this thread i done a forced regen about a month ago and got it down to 0%.
I checked it again about a week ago and it had gone up to 3.6%.
Driving the car today and it went in to 1st stage regen ie.lumpy idle a bit under powered and idle increased slightly.
So got home ran vagcom and soot load is now 22%.
I cant uderstand how it can increase by over 18% in a week even though I havnt done anything different just the normal comute to work etc.
Any ideas!!
Nath.
Jan 1, 2006
8,617
16
OK I have some info for those that are interested.
I took the car out for a good ragging with VC running and took the soot level from 40.8% up. The level reached exactly 45% and then started to reduce very quickly, I guess a regen kicked in. I can honestly say that there was no lumpy or fast idol, no funny clattering noises, no smoke, no lack of power and no funny smells, I honestly would not have known it was in regen. Anyway I continued to drive on the motorway at a steady 60 on the cruise and the level dropped very quick to 20%. I came off at the next junction and turned round and headed back home on normal a roads whilst the level dropped to 2% then it started slowly going up again. When I got home it was on 4% and I guess that it only took about 2 miles for it to go up from 2% to 4% :think:
I did notice that whilst in regen the exhaust temps shot up and at times hit 800 degrees as soon as it hit 45%. The temps calmed down again after was reached 2%. I found that whilst in regen it did not matter how I drove the level always came down unless I was stationary. I also now know that during normal driving, even at 60 on the cruise the soot level still climes but only slowly so I expect to check in the next few days and be on maybe 20% I guess.
Hope this helps
So mine went from 14% to 40% in 3 weeks. and about 150 miles of silly short trips of 2-3 miles each. Next is a forced regen when I feel brave.
IMO the OP of this thread is a hero and needs a beer :yes:
Alzak
663
Hi
I do have small problem with my leon the value on lambda is 10.8 but car is in 1st stage regen how it is possible??
Nath.
Jan 1, 2006
8,617
16
Regen normally starts at 45% so I would say that you have interupted it in the middle of a regen and it is currently at 10.8%, if you drive it steady for a bit longer it should go down to 0% or there abouts and regen will stop. I think that if you interupt it 3 times during a regen, this is when the DPF light will come on.
