Trolly Jack points, not the sill
Mr Pig
2,882
1,062
I've had a search and so far all I can see is people pointing to the sill. However, I like to jack up the car and put axle stands under the sills which requires jacking the car somewhere else.
Every car I've owned has had additional jacking points, usually very obvious. Does the Leon?
Orbiter
Orbiter
Apr 3, 2015
119
Other jacking points are not very obvious because todays cars have the plastic undertray which covers approx the front third of the car. To get the undertray off you would probably have to jack the car up first! If you are just wanting to change wheels around or change brake pads/discs etc I think the sill is the only practical way to get the wheels of the ground. The usual safety caveat about using additional support applies.
Fmxvxx
387
Just jack slightly further back and place the axle stand on the sill Choices for the Mk3 are pretty slim in terms of extra jacking points you can jack on the lower control arms but I wouldn't recommend it.
Ocularis
492
Northampton
You can jack the back from the centre block that has 2 rubber bungs in it (there are pics online from a golf). I jack from the sill and put the stands on that block (for the rear at least).
Mr Pig
2,882
1,062
What points do tyre fitters use when you go for new tyres, as I have not replaced any yet.
Tyre fitters are often muppets who are not exactly meticulous when they jack the car up. I always watch them and I've had to stop them jacking in a bad place a few times. Find out the correct points and always insist they are used. It's your car, don't let some kid take chances with it.
Mr Pig
2,882
1,062
Hi Guys,
Old thread but a couple of things brought it back to mind.
Spoke to Seat again. The four jacking points on the sills are still the ONLY approved jacking points. Off the record, you can jack on the H-frame if you are careful. The other thing that made me think of this thread was something that happened last Sunday.
The brother of a woman I know was helping a friend fix something on his car. I don't know what it was but it involved being under the car. The car's owner was sent to the motor-factor to buy some part or other and when he got back the car had slipped off the jack and the car was sitting on his chest.
The paramedics managed to restore a pulse but three-days later there was still no brain activity. The following day the life-support was turned off and his organs harvested. He leaves behind a wife and three kids. The funeral may not be until well after Christmas as there is going to be an investigation.
It was probably some daft little job he was doing so he cut corners.
Only jack with the car on level ground with a flat hard surface. Do not jack on a gravel drive, seen that go bad.
Use a proper trolley jack.
If working under the car, always use axle stands or wheel ramps.
Once the car is jacked, give it a gentle rock to make sure it is stable on the stands. I did this once years ago when I'd jacked a car on the scissor-jack and it fell off.
If the wheels are off, chuck them under the sill so that if the car does fall it will land on them. Better a wrecked wheel than wrecked you.
Take care guys and work safely.
nicknameless
71
That's awful. I have seen people under the car just on the widow maker supplied with the car.
I am no mechanic and only swap from summer to winter wheels. With the cupra I used the supplied jack with a back up trolley jack (I don't have a hockey puck adaptor for the trolley jack) and then placed an axle stand under the front before doing anything.
Seen too many of those sorts of stories, so always a little paranoid.
Mr Pig
2,882
1,062
It's not an uncommon thing to do. People will often try to do the job with whatever they have available rather than invest in tools they might seldom use. In this instance, I don't know how the accident happened. I don't know if it was scissor-jack that slipped, the car moved or what. I didn't know the guy, I only know his sister and I've not spoken to her since it happened. My wife might see her tomorrow so I might get more details then.
Two of my best car-related purchases are a big Halfords-pro socket set and a 3.5-ton trolley jack. The jack is so good, it makes such a difference. Low entry, high lift and rock solid. Love it!
