Its a good link with some good info. Is Vag Com easy to get and get to grips with as ive used handheld scanners which i know are basic but as i undestand Vag Com is far more technical.
You can pick up a cheap KKL cable on fleebay that will work with version 409 and downward versions or buy the proper one off ross-tech that will give you loads more features, i went with the cheap option as i wanted to see if i would even use it much, but am seriously considering buying the latest version/cable.There are loads of guides on the www.ross-tech.com site and Wiki.Its not that hard to get to grips with, i use mine for data logging, error reading and minor adaptations , some basis adaptations are below, There are guys on here that are extremely competent and helpful with this software.
Basis adaptaiton = http://www.seatcupra.net/index.php?option=com_content&task=view&id=553&Itemid=6
