Turbo Cooling time?
Ronin225
4,652
22
Worcester
It is located under the slam panel, inline with the LH side of inlet manifold
Looks to be an aluminium body so stands out a bit
Mar 1, 2009
1,079
Liverpool
Basically when you have a turbo spinning at very high revolutions the bearings need lubricating.
Turbo's can take a while to spin-down.
When the engine is running, its flowing oil round the turbo, so its being constantly lubricated.
When the engines turned off, the oil stops flowing through the turbo.
If you have just been on boost before the engine is turned off, then the turbo will still be spinning but no fresh oil getting to it, thus oil becoming too hot and looses its properties.
This causes more friction, can wreck turbo bearings and oil seals.
Therefore its always a good idea to keep the engine running just after you've had a spirited drive to allow the turbo to be properly lubricated whilst it spins down.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Codswallop.
The turbo stops spinning right away, there is no gas flow to drive it. However, if you've been driving hard right up to switch-off, the turbo will be very hot, and once the oil stops flowing, the film of oil in the plain bearing will cook and carbonise. Next start-up will be rough on the bearing and the seals (which could be dry, or nearly so) and the carbon deposit doesn't come off easily.
That's good advice (apart from the spin down nonsense, while the engine's running the turbo will always be spinning, driven by the exhaust gas), better to take the last few miles gently though and allow the whole engine time to cool down.
mattdavies
Pre-Facelift Bumpers FTW
Jan 24, 2009
88
Maidenhead
The other day after driving very spiritedly i decided to look at my turbo and it was white hot, i let it cool down loads, but is there anything i should consider after this event ?
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
