Mtech_69
Help needed. Have got a 2005 FR 180 bhp over the last couple of months have had problems with poor fuel consumption and lack of power been to main Seat dealer 3 times and they stated car shows no fault codes so nothing they can do
Once the turbo starts to spool you can hear a whistleing noise like air venting somewhere and this is constant the whole time the turbo is spinning and it is very slow revving past 4 thousand RPM. I have been through and tightened and checked all hoses and cant find any that are split or lose.
Went into different garage yesterday and they advised the uprated forger 007p diverter valve (which i only installed after problems started) was causeing all sorts of problems. After replacing with stock part runs slightly better but garage advises that somethign is still holding back boost but not sure what and it now has a noticable miss fire once get to 5 thousand rpms.
Any help or advise would be much appreciated and problem really starting to annoy me.
. Once the turbo starts to spool you can hear a whistleing noise like air venting somewhere and this is constant the whole time the turbo is spinning and it is very slow revving past 4 thousand RPM. I have been through and tightened and checked all hoses and cant find any that are split or lose.
