Turbo Query
Dizziblonde
Hi all.
What a cracking site.
Soon to be a proud owner of an LCR.
Can someone explain too me what it means to:
Warm the Turbo up in the morning and conversly warm/cooldown the Turbo after a long or short journey.
Thanks.
Apr 28, 2003
2,624
Turbos get very hot when used hard. If i thrash mine i always make sure that the last 5 mins of driving are off boost and at low revs. On starting up the car i dont rev it hard or use boost for the first 15-20mins. Let the oil and water circulate long enough to both heat everything up properly on start up and also give the oil and water enough time to remove heat from the turbo etc on shut down.
Dizziblonde
Madmile many thanks for the prompt reply.
Makes sense to me perfectly apart from the term "off boost"
I presume the turbo kicks in at a certain rev range and if so is this the point you term as "boost"
Conversly off boost is the rev range the turbo idles????
Apr 28, 2003
2,624
Basically dont rev the car hard and it wont produce boost. Just take it steady for the first 15mins of your journey and easy for the last 5-10mins and it will be fine. Check your oil regulary and change it as Seat require.
