Good point about the mirrors. I do the same to retract the mirrors but never realised I'd be disabling the internal sensors. Great design! I hope there are no opportunist car theives reading this.Thanks for the replies. If it's done by pressing the lock button twice does that mean that when I press and hold the button to fold the mirrors its also turning off the interior alarm ??
Will have a try at the weekend and work it out
I tend to press lock once then press and hold again to fold mirrors, so my query is have I inadvertently been disabling the interior scanning.
you will have missed it due to the low level washer fluid light distracting you...... No......ahIt's on the small button a few cm's down from the seat belt height adjuster. Oh wait….
Posts not making sense will fit in well here, any sense made is normally by accident.....some good comments Biker
I guess from your comment that I can just press and hold to lock and fold mirrors without disabling interior alarm. I didnt know that was the case, I've always pressed once then press and hold to fold mirrors
As for Q4 , you are sarcastic but I can see why, my post didnt really make sense![]()
Posts not making sense will fit in well here, any sense made is normally by accident.....![]()
I actually have a warning for the washer fluidSure it's a Winter pack option like the Octavia and Golf.
The golf GTD I had didn't have winter pack but had low washer fluid warning. I reckon they fit the low washer fluid light when headlight washers are installed?
It is a handy feature that imo should be standard as it's not easy to check washer fluid level manually.
I thought the Winter pack was headlight washers and heated jets?
The headlight washers use 5hit loads of washer fluid. Changed them via VCDS to only squirt when I've held the windscreen washer jets on for 2 seconds.
So press once and hold for mirror foldingnoted
I would like to know this. I can't find the button to disable it, how you found it?
As posted above, press the lock button twice within 5 seconds.
