I have recently started to experience two noises on my car. Its a petrol 1.4 and has FK coilovers fitted.
Recently one of the balljoint bushes of the droplink had a split and so had the pair replaced with replacement FK ones.
I have never had no noises, and have had the new ones on for about 2 1/2 weeks with no problems. Recently changed to lower profile tyres and after a week theree is noises started to appear.
Noise 1:
The first noise sounds like a bag of spanners and like somethings loose when the drivers side wheel goes over a hump or road bump.
A garage has had a look and can't find the problem or any play anywhere. Only thing that was pointed out was that the ARB is close to the driveshaft
The pic above shows the distance, which is not a lot. However, even with the old fk links with the busted boot the arb sat in the same position and never had a problem. Is this still likely to be the culprit? Do other people with FK coils have a greater distance or is it the same?
Noise 2:
Another noise is a squeek which is when your moving forward at parking speed. Sounds a concentric noise in relation to the slow wheel movement. Anyone know what this could be?
Any help to any of the noises appreciated
Noise 1:
Noise 2:
