Tyre Size
Spawney
82
Nottinghamshire
Hi. The recommended tyre size for the Cupra is apparently 215/40 17.
I am having a hard time getting hold of the tyres i want in 215/40 17 but can get them in 205/40 17.
Will these be ok?
Thanks in advance
oc1sup
19
Near Milton Keynes
Hi Spawney. There's a table in 'xxx.brick-yard.co.uk/forum/tyre-size-for-rim-width_topic60146.html' that show the min/max tyre sizes that will fit a given wheelrim. I can guess that a 205 will fit your wheelrim without a problem, however you will be reducing the diameter of the wheel (the '40' is a %age of the tyre width, which you are reducing) , reducing the ride height by 4mm and putting the speedo out a little (overread marginally).
I don't think you will notice any real difference with handling - and it is winter now so when(?!) it snows it's considered narrower tyres are better (not that 1cm will make much difference...).
Have a look at tyres-pneus-online.co.uk - they may have what you're looking for and are well priced even after adding the fitting price at your local fitter.
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
what you on about spawney? loads of tyres lad.
CLICK ME
ive just gone from pirrelli to yokohamas
and i understand that 205s are a damn site cheaper then 215s and im probably gonna run 205 on the back of mine and save myself 60 odd quid.
liam TDi
99
kettering
see what spawney means, i really wanted P zeros or Michelin PS3s but they dont do them in 215/40/17s so annoying.
x9moto
80
im running odd sizes on my ibiza goodstuff, i have 215/45/16 on the front and 225/45/16 on the rear and first thing i did was brake hard and abs is working normally, dont have traction control as its the 1.4 85 ps...
Mat
oc1sup
19
Near Milton Keynes
The problem with different sized wheels is normally if you have the smaller/worn ones on the rear I understand (saw somewhere that you should always put new tyres on the back and move the worn/old ones to the front to stop the auto systems getting confused - assuming they're all the same size!). Even so, it would be best to have the same size all round so there's no difference in rolling circumference - that way all the wheels will indicate that they are going the same speed.
I think that with 225 on the rear and 215 on the front that is why the ABS is happy. PS having 225 on the rear increases the ride-height on the rear by 4.5mm - so not much anyway.
I think the puncture sensor also works on wheel speed - assumes the a wheel running faster means it's under inflated/punctured.
Spawney
82
Nottinghamshire
Wow. Thanks for all the replies.
I want the Kuhmo KU39's and Blackcircles and Camskill dont have them in stock in the 215 40 17
Blackcircles have them in 205 40 17. In fact so do camskill. :)
Cheers guys
