Deplunk
60
Birmingham
evening all,
had a coil pack down on Tuesday, changed it yesterday for a new one, waited over night and my engine management light had gone off, decided to plug in VAG-COM tonight, and I don't seem to have an option to clear the faults but 6 faults were found?
here is my log:
VCDS-Lite Version: Release 1.2
Thursday, 09 October 2014, 20:08:52:0
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01,02,03,08,15,17,19,22,35,36,37,46,56
Address 01: Engine Labels: 06A-906-032-AJQ.LBL
Controller: 06A 906 032 HN
Component: 1.8L R4/5VT 0001
Coding: 11510
Shop #: WSC 06441
VCID: 719556C728B1
VSSZZZ1MZ2R068705 SEZ7Z0A1397921
6 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 35-10 - - - Intermittent
17763 - Cylinder 1 Ignition Circuit: Open Circuit
P1355 - 35-10 - - - Intermittent
17766 - Cylinder 2 Ignition Circuit: Open Circuit
P1358 - 35-10 - - - Intermittent
17769 - Cylinder 3 Ignition Circuit: Open Circuit
P1361 - 35-10 - - - Intermittent
17772 - Cylinder 4 Ignition Circuit: Open Circuit
P1364 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.LBL
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0022017
Shop #: WSC 00001
VCID: 321799CBED37
No fault code found.
Address 08: Auto HVAC Labels: 1M0-820-043.LBL
Controller: 1M0 820 043 D
Component: 1M-CLIMATRONIC X0605
Coding: 00041
Shop #: WSC 06441
VCID: 23396C8FA2CD
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 1C0 909 605 A
Component: 1L AIRBAG VW51 0A 0004
Coding: 12620
Shop #: WSC 06441
VCID: 2237698BBDD7
Address 17: Instruments Labels: 1M0-920-xx2-17.LBL
Controller: 1M0 920 902 C
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 05424
Shop #: WSC 00000
VCID: 2721789FD6F5
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
VCID: F093D3C3A3BB
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Controller: 1C0 959 799 F
Component: 3M Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 06441
VCID: 3A07B1EB3547
End --------------------------------------------------------------------------------------------------
:confused:
I have tried going to the engine module and clearing them, but I get an error saying controller not responding, my 'free' version is unlocked, I have cleared a fault before.
Disconnect the battery for 5 minutes and then reconnect. This has happened because you haven't disconnected the battery whilst changing the coil pack.
Hmm, I can see this being a possibility, I will try this next month when I change the remaining 3, but why am I unable to clear the faults only clear the log in VCDS?
Ah, understood. I had a similar problem myself recently. Open circuit faults come with some cheap coil packs. They weren't "Berlt" ones in a black box by any chance?
I swapped mine for a Lemark coil pack and the fault was gone. All four of mine are Lemark ones and I have no problems with them.
See I thought the same thing too, but I did some searching on the Bosch ones and no body seems to have a problem with them, got them from a local motor factors. When checking to see which one had failed, I unplugged each one till one made no difference. Could this be the cause?
No, not the cause because the system clears and self tests each time the car is started. The problem is with the coil pack. Take it back and get it replaced.
Yes, the resistance from the coil pack is incorrect. Mine was the same. Ran perfectly but threw the engine management light on with an open circuit fault. EML= Mot fail. Get them to replace the coil pack with an OEM or Lemark one.
Got the multimeter out today and measured the resistance of each cool pack with similar results throughout.
Up to you my friend, but I guarantee you that changing the coil pack will solve your problem. From your fault codes, all 4 cylinders are showing the problem. I'm guessing that all 4 coil packs are non-genuine?
3 are genuine, and the one I replaced is a Bosch, I may return it and try change it for a Lemark, then replace the rest with Lemark ones if they solve the issue.
In theory, a ropey coil should only throw a fault code for the cylinder it sits on. Not sure why all 4 are doing this if 3 are OEM coils.
