Undertray
W88DSY
Hi All,
Does anyone know of a place where i might be able to pick up a cheap undertray for a 2004 20vt?:confused:
W88DSY
Cheers mate, ta.
Just wondered if i could pick one up without paying full retail...... Thight ass i know!
W88DSY
Hmmmm do you really think i need one? I've been running it without for the last thre months but recently starting noticing light steering from 90mph onwards, thought it might be down to this but it could be something else??
andycupra
status subject to change
id recommend fittin gone, im sure someone had an issue on where with water who was running without an undertray.
the undertray is a large piece of plastic that sits under your engine. it starts at the end of the front bumper and finishes just past the front wheels.
to drain the oil it gets removed and lots of garage break them or dont put them back.
you will need over £100 to replace one!
W88DSY
Directly under the engine there is a plastic tray attached to the underside of the front bumper and goes back roughly as far as the engine does, just think it stops stuff from splashing up on to the engine?
Mar 26, 2007
2,020
S.Wales
ahhhh so not a standard piece then? i've had the lcr a couple of months but havnt had need to put it up on the ramps yet and have a good poke around.
W88DSY
Cheers Andy, i read that too. I'll prob. just leave it then as i@ll no doubt break the new one.... or the garage will!!!
GrayT
I'm Old
Jul 7, 2004
812
London
Don't know about the downforce stuff but in my view they just give a little extra protection and it may be enough to glance the odd stray bit of rock or metal from damaging the sump causing you to drop your oil on the motorway at 70 mph. I guess that it deflects some water away too, although I would have thought that is a lesser issue
In my view, even at standard prices (a tanks worth of fuel for both side pieces and the centre section, or less than half a tanks worth for the centre section only) it's worth it.
Jan 22, 2007
2,074
some may say lala land....
thanks guys - now i have to go outside and see if mine is missing or not - oh well. needed something to do rather than go to work.
[edit]
i managed to find time to have a look last night, phew i do have one. a few more pennies dasved
[/edit]
Smart22186
Newbie
Feb 21, 2006
353
Peterborough, England
Can any one remember that site (i've had a search but cant seem to find it) what sold aluminiun under trays?? would cost a bit more i know but would provide 1000% more protection and it would never break??
BCM
Keyboard Gangster
Feb 1, 2005
2,680
Wishaw, North Lanarkshire
Mine fell off bout 2 months ago too, didnt bother putting a new one back on, been in for a service since too and seat (useless bast*rds) didnt say i had to renew, only noted that it wasnt present, heard someone say somethin about temp of there engine, helps keep the temp down a bit too!
andycupra
id advise refitting one, the timing belt among other things is a bit exposed without it.
as for the aluminium one, unless this gets fitted in a better way this could get damaged easily too. the actual standard undertray is pretty strong, its where it gets attached to the car thats weak.
