universal induction kit and 1.8T
Barry.L
111
Reading
im looking to get a universal induction kit from the likes of jetex or green as induction kits made specific are a rip off imo. has anyone actually fitted a universal kit to there 1.8T and were there any problems? i know the maf is sensitive, but i can't be spending £100+ when you can pick up universal cones off jetex, for example, for as little as £30. any thoughts?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
you can also buy Green ones for same kinda money.
70mm neck size and bung it on for el-cheapo install.
support it a bit tho to stop it flappin.. maf wont like that
heat shield it too to avoid hot air being drawn in..
TimD
472
You mean hot air?
I have some shabby universal stainless steel thing fitted to mine atm, no heat shield, it can't be doing much good in the heat wave we're having. I'm reverting back to an air box with green panel and modifying it.
Barry.L
111
Reading
cheers, i guess id have to make some sort of bracket for it. do you think the maf will cause me probs?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
i use a Dynatwist XXL, currently with the shield thing off it. big arse cone filter essentially.
dav
SEAT owner no more...
Feb 2, 2006
1,077
Kincardineshire, scotland
for the modified are you just smoothing out the insides and making the feed pipe bigger? where is the best place to fit the bigger inlet pipe, in the front (underneith/ beside the intercooler or in the origional position?
CatB1
535
Manchester
www.freeserve.com
Green filter on mine(part No P472),came with bracket to mount on inner wing.Fabricated a shield and cold air feed.
Barry.L
111
Reading
have you had any problems with the maf, ect?. aslo do you know what neck size i will need the filter to have?
TimD
472
Bill, would you say the standard airbox is restrictive in anyway?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
with enlarged intake, no its fine. stick a decent panel filter and large intake pipe.
Adequate for most bolt ons I think inc some Eliminators
Barry.L
111
Reading
well ive just ordered a universal fit cone from jetex for the measly sum of £39. guess i better get hold of some metal to make a heat shield.
flashbsd
me! with std airbox and just a panel filter. modding to come
