tyrrell
89
if i was to unplug the n75 valve (electrically not hoses )
would this mean i would be running actuator pressure?
reason i ask becuase my map isnt right and i would rather run less boost then damage my engine?
i dont have a boost gauge to see whats happening?
can you confirm that unplugging it would do that though?
How do you no your map isnt right what map is it..??
and how do you no its boosting to much if you havent got a boost gauge..??
You no boost is addictive myki...:lol
Fitted my boost gauge the other day with the nomad pillar...tbh though not the best fit though with the nomad pillar would or expected better for the price
still loving watching the needle fly round the little gauge...:drive1:
well i did have a gauge then i took it out becuase it was cheep...
and i know im not runnning the right map becuase its a CC stage one for a ko3
and its got a k04-023 and bigger injectors on it.
:headhurt:why not get it remapped???? to suit the new turbo & injectors
+1......i dont think unpluging the n75 is going to be the solution here...specialy since you now havent got a gauge to keep an eye on things...think it could do more hafrm than good...
i would just take it easy then . if its going there next month leaving the n75 and the actuator well alone:D
Lol,
I was in the same situation when i was running in my hybrid... your fine to run on actuator pressure while not mapped, i did for well over 100miles.
Just unplug it and take it easy as much off boost as you can.
i said becuase the map is not right.
