If you have a LC / LFR, which has throttle body on right side of the car, use a SMIC. It's very hard to run the pipes for a FMIC through the engine bay to go right and feed into the throttle body.
If you have a LCR (throttle body on the left side of the car) use a FMIC, it's just in place to run the pipes where needed.
2 uprated SMICs (Tyrolsport, Eurojet, BoostFactory) can easily be fitted to a LCR in place of factory SMICs, and this would give a total IC volume of 12-16 liters, compared to a usual 600x300x60 FMIC, which gives about 11-12 liters (core + end tanks together), but nobody does that either here or anywhere else, because of cost - you have to pay 600-1000 EUR plus shipping for 2 SMICs, compared to a much cheaper FMIC, some of which can be found for 300 EUR new or 150 EUR used.
~Nautilus
~Nautilus
