mikey_b
322
Manchester
hi people just bought a MBC if i put the boost to 14-16psi whould there be any problems with ecu goin into limp mode?
By MBC, do you mean a bleed valve??? Not sure if many people use them.
Just get a stage 1 remap for more boost, ECU won't have any issues then.
No not a bleed valve well its a spec r boost controller, and the reason i dnt want a remap is that ive just bought a k04 setup and getting the ko4 hybrided, then map that as it would cost more if was to map it now and then after!
