To be honest Paul i adjust my mbc and actuator spring pressure to keep my boost within the limits of the map sensor (1.54 bar). This will keep your torque in the region of 300ft/lb which will keep your rods and clutch intact.so rods should be ok with 24-25 psi??
Bottling up those exhaust gases will push the temperatures up. Are you monitoring your EGTs? I'd say any modification from normal evacuation of the exhaust should be accompanied by a way to monitor how hot your head is getting. An EGT monitor is a cheap item. You should consider it.i personally think, on these, that there is often so much back pressure on the manifold/hot side that it can in fact push open the wastegate which is why a stiffer actuator may hold it shut.
I guess we found out the hard way.Sorry to hear of your rod issues and hope it gets sorted so she's better than ever.
A manual boost controller is essential to keep the peak torque in check.
350ft/lbs is suicide mate and those stock rods won't cope with it long term.got me worried now! I run similar torque to cupramvr ! So is a ebc or mbc needed to keep torque levels down ?
has he broken the rods, on the dyno perhaps? I can't find the post.
yep, has thrown a rod through the block while driving from what i've read![]()
Uh Oh. This was after the hybrid got fitted?
