Uprated/adjustable top mounts
knackerdecobre
Thing is, adjusting camber from the ball joint messes with all the other settings. Likely to give you toe out mainly
TissMe
Yes it will effect it , b ut the beauty is that the to out will be adjusted back when the geo is done
This is the thing that the Golf 4 chassis guys have off the TT`s , that is a good one
But never anything been done for the Fabia , and Ibiza guys
Sarah
knackerdecobre
For me, the idea of having adjustable topmounts is so I can drive to track on 0-0.5deg of camber, whack it up to 2-3deg on track, then stick it back for the drive home, without having to touch any of the other settings. Adjusting the lower is ok, if you just want the one setup though
TissMe
Well I never did track , and dont want to pay £400 for the top mounts , and I dont have KW coilovers and dont want to have to replace the Koni suspension kit I have
So I got off my backside and did something
Shame that people find it very easy to critise
Sarah
knackerdecobre
I'm not criticising the idea, its good, I actually thought about it when I had the wishbones off. It's ideal for the majority who just lower their cars and want to sort the camber, I'm a fussy buggar though and always want that bit more :)
TissMe
That is OK then :p
It took no end of planning and then getting it done professionally
Cost a fortune too , but now selling car so , not needed
But hey , I must admit , I have thought about getting a few of them , as I know so may had the issue
Sarah
joop200789
330
Barnsly
sarah i have the same thing done to my bottom arms.
great kahn if you look on the other link i posted kws one you can buy them direct for 206 dilivered still steep but will save tyres like no tomorrow
russ tdi thanks for pictures makes you post clear as a bell so if you got striaght cut spring and enough thread theyl be able to be used and if spring arent striaght im sure i could make a plate to make a stright base for the mounts
great_kahn
Spooge
Nov 19, 2009
2,415
Leicestershire
http://www.kw-suspension.co.uk/clubsport/products.php?vid=78
And these will work with any coilovers? Legend mate, these are just the job.
joop200789
330
Barnsly
i think as long as top off your springs are flat and that there enoguh thread to get the nut on they should fit. And if the spings arnt flat am sure a base plate can be knocked up to solve this
but am guna look more into it first
and off tolp of my head fk ak coilovers the springs are flat at the top
