S13
85
Hi
Just had the engine management light pop up. Drove home and connected it to VAG COM (free-version) which came up with this fault:-
VAG-COM Version: Release 409.1-US
Control Module Part Number: 038 906 019 LA
Component and/or Version: 1,9l R4 EDC 0000SG 5405
Software Coding: 00102
Work Shop Code: WSC 00000
Additional Info: VSSZZZ6LZ4R198267 SEZ7Z0D2475379
1 Fault Found:
16485 - BÊ~#o#SˆH{bñø]'K=`N?eGÍ<YO\ñpk£OIÁng7?_uNÇf9
P0101 - 35-10 - f - Intermittent
Could anyone please tell me what this is?
Quicker the better really as I don't want to drive to work tomorrow if it is going to cause any harm.
Any help very much appreciated!
Many Thanks
Sorry, I think the fault is:-
16485 P0101 Mass or Volume Air Flow Circ Range/Performance
Is this right?
If so, what does this mean and what is wrong?
IS the car safe to drive?
Many Thanks
think its your MAF sensor sir, should'nt cause any problems, so ok to drive, but may lower performance. but sure someone cleverer will tell yu exact problem.
Why did you find it, or was it just a regular check, engine light on???
Great, thanks for the reply.
Yeah the engine management light came on so came straight home.
Will the MAF sensor be covered under warranty do you know Ant?
Thanks stoney, yes I've cleared the cod. Light didn't pop up again when I started the engine but haven't taken it for another drive yet to see if it re-appears.
Car felt fine though, exactly the same as normal when the light came on.
just take it easy in the morning , prob just a hiccup , rescan 2moro when u get home , id say the code wont be there , ive had a few "phantom" codes
