Vac line trough the firewall
Feb 19, 2024
Hi, i have a fr 1.8t and im installing a boost gauge but i stumbled upon a minor problem.
I removed the ecu, tracking dows the wire loom but i cant see where the its going trough. A bit of help with some pictures would be nice. Its also a left hand drive so i cant use the gromet on the other side. Thanks in advance.
Jun 22, 2024
Run the vac line behind the dash into the passenger side grommet, or you can try run it through the same place the bonnet cable goes through, it under the plastic cover under your windscreen wipers. if you remove the cover you should have access to a couple grommets there.
