Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
2 Faults Found:
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-10 - - - Intermittent
17863 - Exhaust Gas Temp Sensor 1 (G235): Implausible Signal
P1455 - 35-10 - - - Intermittent
Readiness: 0000 0000
Can anybody shed some light on this please?
read this on 'Intermittant codes'
http://www.seatcupra.net/forums/showthread.php?t=163676&highlight=17863
Also what's the maf reading MAX g/s?
Hi not sure about this will check the MAF G/S when I return home monday. I read the thread many thanks will also give this ago monday cheers bud!
have you read this
http://wiki.ross-tech.com/index.php?title=Category:Fault_Codes&from=02071
unfortunately the second is not on there
had a check for leaking pipes or for holes but they all seem to be in really good condition can anyone point out where the cabon canister is? cheers
Cheers. I seem to have solved the problem but not sure how. Only things ive done recently is..
1. Updates VAG COM to 805
2. Cleared out the gunk from the small hole under the petrol nossle hole thingy
3. Changed my coilpacks
Anyone think this could have solved it?
my MAF reading was 187 on load, sometimes peaked around 200. I think ive solved it by cleaning out the gunk from a small hole under the filler cap, cleared the codes and its never returned. I read somewhere on the internet the hole possibly allows gases to exit the fuel tank?
