has anyone bought vag com software from ebay? the lead and free software? if so, how was it?? worth the money? its fairly cheap from what i can see, around £13! including usb lead, or is it just too good to be true??
Pah, outdated device - no updates anymore, so you are stuck with Basis 12.
If you really wanna spend money, get a 5051B or a 5052A - but then we're talking about 5-10k
Besides, what the VAS doesn't do...
data logging
real time graphs
real time gauges
graphic TDI timing checker
turbo mode for viewing live data
coding latest models requires online access and even then only gives you the factory values without a chance to do personal adjustments to those values or even retrofits
A 2004 Seat Leon must be the "old" 1M model which your question about the Octavia is not so clear. In 2004 there were 2 types been sold, the old 1U and the newer 1Z. Depending on which you are talking about the answer you are looking for differes.
I don't want to change anything, I just want to see if I have a fault. The Leon seems to have an electrical issue, as the windows, remote locking and interior light no longer work. Seems silly to spend several hundred dollars on a kit, when even the dealer won't charge that much
The Octavia is a Mk1 vrs, not sure about 1U or 1Z
The leon is a 54 registered Mk1
You can always get together with someone on this forum who has the tool and let them scan your car. The cost might be a couple of beers - even less than the dealer.
